Discuss Meanwell driver elg-150-36a in the Lighting Forum area at ElectriciansForums.net
Trying to extend the 2 output wires safely(around 2 metres),i don't have much previous experiences with electrical appliances but I Did some research and I need a wago connector block possibly 2
Which rated blocks are suited ? I don't know if the 36a gets split in half on the outputs
The job is a simple one , but I want to make sure everything is matched correctly
Thank you for your time
Highest Regards ,Lee.
This driver produces 36V at up to a little over 4A - any Wago connectors that are suitable for the stranded cable will do (lever type). The connections ought to be enclosed e.g. in a Wagobox.
And you need a separate Wago for each of the 2 wires - join the output wires together in one Wago and it will likely either shut down or blow up.
You could use two Wago 221 in-line splicing connectors, which as said above are suitable for stranded wire, and use 1mm or 1.5mm csa flex to extend for just a couple of metres.
Edit - maybe actually four Wago's will needed, two at the Meanwell end and two at the lighting end!
Reply to Meanwell driver elg-150-36a in the Lighting Forum area at ElectriciansForums.net
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Moved into a refurbed flat a couple of years ago and there were a few suspect things about the electrical work which I’ve not got round to...
Left over stock, all brand new unused in boxes. Looking for £150 job lot. £10 postage or can be collected Description: ELG-75 series is a 75W...
Last time I posted on forum it was on the thorny issue of over unity machines which alas got confused with perpetual motion -- and other supposed...
8K
A
Before I begin, I put my hands up and admit I'm neither a sparks by occupation, nor a qualified domestic installer, nor Part P qualified. I do...
23K
Boatelec
B
