Discuss MEM RCBO REPLACEMENT in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, can I install an EATON Rcbo in place of an MEM C32 MR30 Rcbo? I understand that Eaton have bought MEM, our merged. I know it's not good working practice and can invalidate insurance but I'm struggling to find an MEM C32 Rcbo and the client isn't going to replace the whole board.
New eaton rcbos don't fit old eaton or mem boards. There are older ones which fit some mem boards and should still be available but the new design aren't even close to fitting.
CEF have them on their website, I've had to get a few before. If I remember rightly, you've got to buy the MEM C32 MCB and then the MR30 "pod" attachment which pretty much clips on to make it an RCBO.
The Eaton ones will fit an MEM Memshield 3 board no problem. They won't on MEM Memshield 2 though due to the wider busbar. I've not seen anything that actually does fit on those correctly, but seen a fair amount butchered into place
Memshield 2 and Memshield 3 (now known as just Eaton) and are in no way interchangeable. As noted in #5 you need the rcd pod and a Memshield 2 device with the latter versions having Eaton on them and not indicating Memshield 2.
HI,
The It's an old MEM2 board then the others are correct MEM2 MCB and MR30 Pod. Save yourself some money though at get it from us. We're cheaper than CEF even without your 5% discount.
We're currently out of stock of the MCB but we have the MR30 Pod in stock and it's £16.82 cheaper than CEF and you get free delivery. And you'll be supporting a forum sponser ?
HI,
Apologies for the CEF link?
I have actually bought the pods from you in the past.
Reply to MEM RCBO REPLACEMENT in the UK Electrical Forum area at ElectriciansForums.net
Just to be clear… I am going to do the correct thing here and pay for the correct parts…. I just wanted to start the discussion. My particular...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Hi Doing my first Inverter and Battery install on a domestic property having just completed my EESS course with LCL. Question is how do I...
6K
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
