Hi, currently working on a shop refurb at the moment.
It's a traditional building( bricks and mortar) with a house attached on the back.
The house and shop are on the same supply and meter for the time being. To move the project along we've had move the supply and meter to a new position.
DNO did their bit but meter fitted has refused to connect it all back up as he wants a Rod and RCD upfront due to the building works going on inside. (only one double socket is in use for builders)
I get this to a point but as the House/shop install is fully bonded and earthed does this still need to be done as far as BS7671 goes? I don't have Regs to hand but my understanding is if all extraneous and exposed parts and connected to earth then it's OK to stay PME.
He just said it was EDF policy and couldn't do anything unless it was sorted.
Other Electrician is on site now doing this and hoping to obtain a decent RA as they also need a test certificate before energising.
Do they work to BS7671 or is there another regulation they're working too? Can anyone shed some light on this as I don't want to get caught out again. Happy to admit I'm wrong if that's the case!
