Discuss Microwave - 20A Circuit Required in the UK Electrical Forum area at ElectriciansForums.net
canadian
Hi everyone - new forum member here, looking for some guidance / advice before I try this myself or hire a certified electrician
From Quebec, Canada. House was built in 2009, with everything seemingly 'up to code' -- previous homeowner spared little expense. The microwave in the kitchen has a normal (15A?) receptacle on it (see picture 01.jpg attached). Just purchased a Frigidaire FPMO3077TF microwave / convection oven combo unit that apparently requires a dedicated 20A circuit - it even has a special (20A?) plug (see picture 02.jpg attached). The microwave is on its own circuit in the fuse box. I took out the receptacle to look at the wiring, trying to figure out if I can simply swap out the current 15A receptacle for a 20A one (see example in picture 03.jpg attached), but from what I've read, the wiring behind it needs to be 12AWG instead of 14AWG. Is this true? I removed the receptacle to have a look at the wiring behind it - I can't seem to find my caliper anywhere, but from what I can (roughly) measure, it's around 3mm in diameter, which from what understand is ~8-10AWG? Can anyone tell me from the picture of the wiring (see picture 04.jpg attached) what gauge this is? I see no marking on the wires themselves.
More importantly, do I have this all pretty well understood?
to me that cable appears capable of handling 20A, but wait till Megawatt sees your post. he's far more conversant with US and Canada's cable sizes and codes.
Reply to Microwave - 20A Circuit Required in the UK Electrical Forum area at ElectriciansForums.net
Hi, I've a 50A circuit (looks like 6 gauge wire - see image) that used to service an old hot tub and I want to convert it to 20A 12/2 to service a...
FYI --- This is a U.S. installation. I'm replacing a three way switch (the UK might more sensibly call it a two way switch??) with a Kasa Smart...
Hi all I have a professional coffe machine working at 220 V and it currently drain about 2,5 kW of power. I have made this simple and horrible...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
