E
ed-ectrician
Ok this seems fairly simple - minor works not ok if you have to put in a new circuit right?! What if you found some lights that had no CPC in them and put it in - steel conduit - easy enough just pull single green and yellow thru, terminate and do relevant tests. But..... Minor works or new install cert? does just the CPC count as a "new circuit"
