Discuss Mixing TT and TNCS supply systems in the UK Electrical Forum area at ElectriciansForums.net
We only have a reliable solution if all 3 phases are present
the current signle phase options are not really a solution
I think the DNOs should implement PEN fault disconnection as they have access to all phases easily, but that would require more cost
Don't some EV car chargers have PEN fault detection? I think there is also a standalone system that can detect PEN fault..
I cant see any DNO ever implementing a PEN fault disconnection as that would cost them money, I think the next edition of wiring regs will have all sorts of fancy earthing because the DNO's no longer want to provide a reliable earth so cant see them will to accept responsibility to disconnect a PEN fault.
Can you show a link of where it says you have to have a TNCS if doing a rewire... First I have every heard of this...
The DNO (ESB) will only provide you with a TNCS supply. On coming across a TT supply, a REC (registered electrical contractor) is obliged to issue a "Notice of Hazard" to the homeowner, alerting them of the requirement to upgrade to TNCS. No exceptions are allowed.
On the most recent "Safe Electric" newsletter, they doubled down on this by stating that metal sheds may not be connected to a converted TT supply (see March 2021 newsletter under "faq, s" on page 12, I think).
Agh ok your in Ireland....
Has the nature of the hazard been described?
Is it this very issue of TT'd homes returning open PEN current via another's neutralising link?
The description of the hazard would simply be termed as the home being "un-neutralised".
Yes. That's one issue. But main issue is the gradual disappearance of the metallic network that was deemed essential for a sustainable TT system.
These systems only disconnect the supply if the L - N voltage is outside of range of 207v - 253v it is still very possible to have a PEN fault with a dangerous voltage present on all exposed metal work and these devices would be non the wiser, therefore they do not protection against PEN faults in everycase
Other products have a device which senses any current flowing on the CPC, these require a person or animal to receive a shock for a very short duration in order for them to disconnect in a PEN fault scenario
So as yet we do not really have a satisfactory single phase PEN fault detection/protection device
A protective device that requires a person to receive a shock
Hmm
Not sure I like the sound of that
Reply to Mixing TT and TNCS supply systems in the UK Electrical Forum area at ElectriciansForums.net
Carrying out a EICR in a commercial setting. In the main intake room the DNO supply comes in and it states clearly this is a PME system. 5 years...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
