Discuss Moving from Installation to Maintenance in the UK Electrical Forum area at ElectriciansForums.net
Thanks for all the replies. I want to be doing fault finding, problem solving etc. Not just changing lamps and broken sockets. I’m finding that on the install side I’ve lost interest. Mainly because it’s not about doing a good job anymore, it’s all about throwing it in. I’m very conscientious and like everything to be spot on. Having to throw it in to save time is not my cup of tea. But it is beginning to be the same whoever I work for. I’ve lost that fire in my stomach for it. I feel a different direction will re light that fire. I also have a family and I’m just not prepared to travel all over the country anymore. Currently I don’t work for a bad firm, although the work is not testing me and boring and I’m always local so I have plenty of time to find the right position. I will not be rushing into it and taking the first thing that comes along.
Hi Gary,
I did 12 years in the RAF as an electrical and electronic technician, left in 2015 and worked as a contractor for a flower automation company where it was a steep learning curve in comparison to what I did in the military! I then moved into the food industry as a multi skilled engineer and I love it. The money's good, hours are steady and it's always different! You obviously get the repetitive stuff but that's mixed in with frantic fault finding! You get some real head scratchers and spend some time buried in wiring diagrams...if you have access to some! Otherwise it's following cables!
I say do it! Start with a smaller company, learn the controls side of things and move after your learning curve steadies out.
Good luck mate!
@Pete999 @rapparee doesn't mean to be disrespectful , he is not that kind of lad . It is like us saying " what can possibly go wrong.....
Appreciate that comment ruston thanks, I never meant to assume anything, maybe my post was misinterpreted, never meant to put the OP down, if it did seem that way the apologies to the OP, what I meant was, it seems that moving from installation is not as hard as it seems, IF i could do it then most other guys will have no problem adapting, personally I wish the OP well if he gets the new job.
I will be doing it. Made my mind up now. My mate who has just done it is on 10k a year more than I am. That alone is enough incentive to do it. He comes from my back ground but has had some experience of quarries. Conveyers and motors etc. I know I’m more than capable of learning what I need to know.
I’ve been a maintenance electrician for 24 years now (in the RAF until last year funnily enough). As has been said the pressure really comes on when something’s down. I work on wind turbine lifts now and the pressure to get it fixed when it’s down can be quite high. Nobody reports the little problems that are the indicators of something bigger happening because they don’t want to lose the equipment. That means when it does break it’s always a huge drama for the users. I enjoy the fault finding but I miss having another electrician to bounce ideas off like I had in the RAF. That can increase the pressure for some reason.
Your new employer will know your background and cant expect you to 'hit the ground running'! they will need to at least provide some basic training in the areas/machines you are expected to be working in and if it is a big company there will be others there to help!
In my opinion you don’t have to worry about the motors as much as the control side. If you’ve voltage to your motor and it’s not turning it’s kaput, that’s as complicated as it gets. If you’ve no voltage then you’ve a whole circuit diagram of control circuits that are preventing it. As long as you’re confident in your fault finding you’ll be good. As someone else has already said your employer will have to give some sort of training on how the equipment works to give you that base knowledge anyway.
@Pete999
It was only a joke.
I can just picture you in Dad's Army.
Reply to Moving from Installation to Maintenance in the UK Electrical Forum area at ElectriciansForums.net
Hi there I’m liam and I’m 18 years old from Merseyside area, I’ve just completed my level 2&3 electrical installation and maintenance at widnes...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
my son has recently had an ev charger installed for his car (last week) cost was £900, simple run ,consumer unit on outside wall ,drill through to...
Evening all, I have a little conundrum I need to get resolved. I’ve moved an EV charger from a single phase board that was on a 40a breaker and...
