Discuss Multi CU's off 3 phase DB cable size in the UK Electrical Forum area at ElectriciansForums.net
A
Adnan
Hi
I'm new to the electrical trade. Re-wired a few domestic property's and done odd few fault finding jobs. Today I came across a job, converting a 6 bed house into multiple flats (passed it on to a more qualified/experienced electrician).
Just out of curiosity now, If I was to supply single phase to each consumer unit off the 3 phase board, would the supplied cable to the consumer unit still be 25mm if in total it had 3 circuits of total 78A (ring,light,shower)??
Thanks in advance :)
A one bed flat…….. A bit of 16mm is more than enough.
I’ve posted this before on here. I have a one bedroom flat. OK the heating and cooking are by gas. I installed a 6A RCBO and reversed the supply through it. For a week it never tripped. My actual electricity consumption could be handled quite happily by a 1.5 T+E.
I'm taking a cut off the electrician I've passed it onto ;) .. I like to do things correctly and this landlord has a few more property's he wants to do the same! After I've finished a rewire I'm on at the moment, I'll be covering the other houses. I'll have a better view on what needs to be done because I'll be having a look at this electricians work as he progresses. (I like to walk before running)!.. Thank you D Skelton and Tony
Reply to Multi CU's off 3 phase DB cable size in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m an industrial electrician, so when it comes to DB regs and such my experience on them is a little limited. I need 2 x 16A 3 phase supply...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Hi all, new to this thread and just looking for some views. I have today attended a industrial unit which is being converted into small...
