Discuss Mysterious problem in ceiling lights in the UK Electrical Forum area at ElectriciansForums.net
Lew19
I have noticed that sometimes there is a delay between flicking the switch for the overhead light in two bedrooms and the light coming on. The bulbs are ok and this doesn’t happen all the time but when it does it is as though the bulb is struggling to come on. An additional concern is that both these rooms border a slightly dodgy house next door. What are the possible causes? And what should I do to rectify please?
Sounds like a loose connection somewhere. Is the problem restricted to that room.
What type of "bulbs" are they?
By a delay in starting, how long? 5s 0.5s.
I've seen some LED lights that have a delay (probably a cap charging) although this delay is noticeable to the human eye it's probably less than 0.5s
You need to employ an Electrician to sort this problem for you, could be a simple fix, but one that could be disastrous.
I find that Tulips have the least delay time,
I have a couple of outdoor circuits with a number of CFL lamps on each, on switch on the lamps all light at slightly different times. Circuits are all ok.
CFL lamps can take slightly longer to start. Try a normal lamp (or 'bulb') and see if it cures it.
The further away the fittings are then the longer the delay as electrickery needs to travel the length of the cable, if its down hill they they will light up faster then if up hill.
and downhill is the way this thread is headed. :eek::eek::eek:.
Buzz...you should know better,than to post a picture,of a fellow forum member's property - without appropriate permission...
If you look carefully,at the middle,first floor window...you can see my missus and her furious expression...
Liar, you don't have a wife it's you and your moobs on display.........
Reply to Mysterious problem in ceiling lights in the UK Electrical Forum area at ElectriciansForums.net
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
We are having issues with our electrical system. In the garage, dining room, kitchen, one of two bathrooms, master bedroom and the front yard...
I have a 2-gang box in my home, built in 2019. 1st switch controls a ceiling light (flush mount LED). 2nd switch controls a ceiling exhaust fan...
