Discuss Mystery light switch????? in the DIY Electrical Advice area at ElectriciansForums.net
Hi,
Ive joined the forum to get some advice/answers on a light switch I have in a new home I've bought.
Its a 4 way switch in my kitchen/diner, the first switch operates the under unit kitchen lights, the second operates the ceiling lights in the kitchen end of the room, the third does nothing, the fourth operates the ceiling lights in the dinning end of the room.
My question is should the third switch be doing something, if not could it be used to operate all lights in the room or even just all the ceiling lights? Ive attached a PDF of the switch for reference.
  • Switch.pdf
Do you have any outside lights?
Someone intended it to do something otherwise the switchwire would have been left out.
The switchwires are even marked with 1 2 3 4 bands.
What about lights over the top of units?
Or plinth lights?
Or plinth lights?
Rough old way of marking live conductors though snowhead, don't you think?
Old school, like both of us
We used to put nicks in with cutters, but cut the nicks off when terminating.
In more recent times I've just used a permanent marker and left the bands on.
cheap job. just because wagos cost a little more than choc blocks.
Kinda like the "mystery" light switch idea! I have one in my utility room that does absolutely nothing...it used to control an outside light, but when I put LED GU10s in the utility room it tripped the mcb whenever I switched it on. I put a new circuit in for the outside light, from the garage and all was well.
I am moving house soon, and love the idea that the new owners will switch that useless switch on and off, looking round the house, wondering what it does!
Is this a brand new or nearly new house? Sometimes in a new house, I've seen cables installed for something that is not fitted, as the buyer didn't want to pay extra.
before moving, you could use that switch to feed a motorised jolly roger flag.
If there's downlighting throughout the kitchen/diner, I'd wager it's for a pendant light in the dining area that was never fitted. Have a look above any logical dining table positions, you'll probably find another choc block in the ceiling.
Maybe I'll just wire it as a 2 way...then they can hit one switch to put the lights on, and the one next to it to put them off? That should keep 'em amused for hours!
I assume this is a newly built house? there should be a sticker on the consumer unit for when the next test is due this in most cases has the electrical contractor attached also, as they did the wiring they should be able to tell you if not go through the developer. As already posted it could be for extra lighting above the kitchen units or plinth lights if chosen and paid for.
Hi, the house is 5 years old, I think the assumption that it was for something the original buyer has either not wanted or couldn't afford is correct. With it being on the dining room side of the switches the pendant light seems like a good bet.
Reply to Mystery light switch????? in the DIY Electrical Advice area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
