Discuss New member first post. load on dimmer leds flickering. in the The Welcome Forum area at ElectriciansForums.net
Is the dimmer suited for use on Led lighting? Many aren't and will only dim to a minimum wattage, which is often higher than the wattage of the led lights in a room.
Sorry guys.
I thought I'd removed the technical bits and just posted a introduction.
Clearly my sausage fingers had other ideas.
I've posted the issue over in the electrical wiring forum if you would like to take a look.
Mike
Reply to New member first post. load on dimmer leds flickering. in the The Welcome Forum area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
