Discuss NIC & Diversity to cooker/hob on single 6mm Radial in the UK Electrical Forum area at ElectriciansForums.net
Of course they will not apply diversity to a 6mm² radial because any normal oven with separate hob will be over 32A total load and so need a 40A breaker and probably not allow a 6mm² cable (if in conduit), therefore they woudl be applying diversity to a 10mm radial!
Oh hang on then they could use a 32A breaker and a 6mm² cable.
To be perfectly honest I think I would have offered the same advice to your nic bloke as I did to the nic office monkey I spoke to on the phone a few weeks ago, "stick it where the sun shineth not and then proceed to go forth and multiply"
Reply to NIC & Diversity to cooker/hob on single 6mm Radial in the UK Electrical Forum area at ElectriciansForums.net
I've been asked to change few double sockets, but not keen on touching after seeing 6mm cable, so did a bit of checking as can see the kitchen...
4K
Hi all, Recently a mate had a new kitchen fitted, he's gone for an induction hob and pyrolytic oven, no gas at the property. At 1st fix a single...
4K
  • Locked
5K
Hi all, Looking for some advice if possible please! Got one if then jobs that you get roped in to and that’s turned from a quick simple...
