Discuss No Output from Temperature Controller in the UK Electrical Forum area at ElectriciansForums.net
Hello guys, I am using Shinko BCS2R00-00 temperature controller for a packing machine. The indicator shows that the output is on but there is no voltage output from the controller output terminal. So, the mould was not heat up. I have change to a new temperature controller, but still have the same problem. I would appreciate some help. Thank you.
To get output voltage from the Control relay contact you would need an Input to it, have you got voltage in?
If not does that input go through an over temperature trip or other safety device before it goes to the temperature controller control relay output?
Thank you for the reply sir, i have found the problem. The temperature controller model is incorrect. Thank you for replying.
Reply to No Output from Temperature Controller in the UK Electrical Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi Guys I seem to have an issue with voltage coming back from a QTX 15 pa I was getting a lot of hum (I have a pair and confirmed it's the same on...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hello everyone. I have a inverter configuration problem I thought someone here might be able to help with. I'm not looking for a specific solution...
