Discuss Non-Electrician Need Safety Advice in the UK Electrical Forum area at ElectriciansForums.net
I think I have seen your front garden........hi, i have a similar spa. it has a RCD built into the lead. if you look, about a few inches from the plug ( the main one, not the elv for the lights) there's a big black lump. it's a 10mA RCD. with the lead plugged in ( to your kitchen) press the test button on the lump. it should trip. in theory, this RCD should prevent any shock levels that could cause injury. however, my take would be that you have fauly wiring in the conservatory, and you 1st call should be to get an electrician to investigate. whereabouts are you. 1 of us may be close.
Reply to Non-Electrician Need Safety Advice in the UK Electrical Forum area at ElectriciansForums.net
