Search the forum,
Discuss Old 6MM Grey sheath black and red protective insulation etc in the Electricians' Talk area at ElectriciansForums.net
I
ian65
Plesae could some one give me the values of the CPC for Greay with black and red sleeving as i am doing an install and especialy the 6mm is definately not the same as Brown & Blue
Any help welcome thanks Ian.
Hi thanks for your replys,
i am doing an install and it definately looks more like 4mm than any thing else trying to put a yellow and green sheeth over is not so easy apart from cut some larger ie. 10/16mm cpc cable and use the sheath. The cables are already in situ and looking to completely finish so i can then get it inspected as i am not part of a notifiable group as yet but i will be doing all paper work for new install for consumer unit and new 9.5Kw shower and fan
Many thanks for info all, Ian
Hi the 2.5mm looks to small and trying to cover for 17th with sheath is inpossible and i am not using tape looks very tacky and not professional. This is a test peice for joining a notifaible group at the end so every thing has to be in order. Many thanks for your reply, Ian.
Reply to Old 6MM Grey sheath black and red protective insulation etc in the Electricians' Talk area at ElectriciansForums.net
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
I’d appreciate your professional views on this question, as I’ve had 2 of the associated electrical bodies quizzed on this.!!!! ON changing/up...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Getting desperate to clear my small garage, and I have a bit of old red/black T&E. I used a few bits to add a socket or two in my flat and a...
Hi, I'm getting conflicting stories about this, I wonder if someone could put this to bed once and for all. I'm replacing a consumer unit in the...
4K
