Discuss Outdoor socket in the DIY Electrical Advice area at ElectriciansForums.net
I am going to put a socket into some brickwork surrounding a BBQ area. Now all the external sockets I have seen are all surface ones about 3 inches deep this sort of skt.
Now I thought of using the type of socket one gets on the outside wall of a caravan like this which will sit more flush to the brickwork.
Any other options/opinions gratefully received.
Not got a link by any chance. I have searched youtube and cannot find anything re flush sockets or a guy called Keiran.
@westward10 has posted the link.
Don’t take the installation seriously whatever you do. Probably one of the worst botches I’ve ever seen in my life. Well worth a watch for a laugh though.
Best advice I can give you is pop to a local wholesaler, explain what your trying to do and they will be able to show you various designs which look aesthetically pleasing. ?
Also just bear in mind that installing a outdoor socket is best left to a qualified electrician as it will need additional protection and testing and inspecting correctly.
Every time I watch this I think no he isn't going to, yes he does. Do we think he ever connected a cpc to the actual socket front plate.
British General IP66 13A 2-Gang DP Weatherproof Outdoor Switched Socket - https://www.NoLinkingToThis/p/british-general-ip66-13a-2-gang-dp-weatherproof-outdoor-switched-socket/67928
Our electrician fitted these. I think I messed up his tea order one day and this is how he got his own back. They are very difficult to un-clip and clip-shut - but as a result are always very well sealed closed hence IP66. I have to kick them open and closed - perhaps my age though. Actually I am content - they will stand the test of time. But, if you want/need easy open and close be careful what you buy.
They are the big bulky jobs I do not want in this case.
Having seen the video methinks I will stick with the caravan socket.
Isn't that caravan socket only waterproof when fixed to a flat panel though? Not sure how it would fair on a brick wall.
Well the caravan wall is flat agreed but if you have ever taken one off there is usually about half a tube of sealant stuffed behind. I think a caravan socket sealed to the brickwork will be fine especially as it is not exposed to direct rain.
Reply to Outdoor socket in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Just had three split Air Con units installed at my home, the ones with an indoor and outdoor unit. I (perhaps naively) trusted the installers...
