Discuss Pat testing UPS in the UK Electrical Forum area at ElectriciansForums.net
P
Paullestrange
Hi,i will be starting a new job in a weeks time,which involves a certain amount of PAT testing.As my experience lies within the Industrial sector i was wondering if any of you guys could offer some advice / guidance on how to test UPS.Thanking you all in advance.
Paul are these the rack mountable/ Tower 5 -10KVa type your talking about or the larger independent ones?
If they are the rack mounted smaller type you would test the same as any class II IT equipment, but you would need to arrange a shutdown on them.
The larger ones will most likely have a dedicated maintenance regime built into them by the most likely the supplier
Hi Malcolm, i would presume they are going to be smaller type. My problem lies with after safe isolation the UPS Batterys will still be servicing dedicated safety systems,IT equipment etc
To be honest Paul I have yet to see a PAT sticker on a UPS.
It really is not a piece of Equipment that normally comes under such a regime as often there are much more stringent checks and frequent checks done on these than your average office equipment.
Often batteries are checked quarterly and I have known them to be done monthly, and during that time with the unit shut down you normally check over the unit such as fans, filters etc.
Most modern day UPS are so sophisticated that they even include a management system that is often linked to either a BMS or a service station and that will give you all the performance and test readings you need
Malcolm,I would agree with you that UPS would/should be linked to a device such as BMS.I was made redundant Three Months ago,and as i stated in my opening thread i have been involved with the Industrial side of our Industry for longer than i care to remember,with that said you can imagine im not so well up on my PAT Testing.I do know what i would call the basics IE Class I Class 2,the different test between each,but the finer points like testing IT equipment without frying its boards,etc etc etc I mentioned UPS only as a precuation as this topic was mentioned at initial interview.
Then as I said in my original post Paul if they are the small individual units that is to power a single work station tower/laptop PC you will test it as any other piece of equipment in the office according to it's class.
I would though imagine that you might need to battery test more than the once yearly normally recommended with office equipment or for IT equipment 2 yearly as most is class II.
I would recommend you treat a battery test similar to emergency lighting quarterly and yearly regime
Malcolm, your a Gent. Thank you very much for your help,you have reduced my fears somewhat,i believe Pat Testing accounts for 20%-25% of my new position (Fingers Crossed)so yes im a little more confident,but realize i still have a lot to learn about Pat. Cheers
No problems Paul hope all goes well for you. Have you got a copy of the Code of Practice for In-service inspection and testing of electrical equipment?? Try to refer to it as that if you can, as that is what it really is, and technical matters often confuse the bean counters.
As an Industrial sparks you should fly it mate.
Well thanks for your vote of confidence,its just the getting your head around new things(when your Fifty it gets harder) the CoP,i believe i will be getting from the company,Yup a company that looks after its obligations and Employees.
Reply to Pat testing UPS in the UK Electrical Forum area at ElectriciansForums.net
I got a TEXT message (i dont know them and i cant find out who they are from the phone number) "Hi speaking from Indeed Are you available to give...
Hi guys and gals, I have a question about the leads to computers (commonly known as kettle leads). I am new to PAT testing so please bear with...
Hi all, I am starting an apprenticeship next month as an electrician within a data centre and was wondering if there is anybody on here with...
Hello fellow sparks, I’m looking to do my testing and inspection course which starts on the 30th of April, but I have not got much testing...
