B
BangTidy
Been to specup a new install on a Server Room. They are planning on extending the serverroom for more cabinets the problem is the current DB has no more free waysand have been ruled out upgrading the board for more capacity due to shutting thewhole system down. Have been told by the IT geek (FREAK) that online access isrequired at all times due to staff working in different country's around the world.
What planningon doing is bringing in a new DB but the IT chap is wanting some kind ofdormant supply's on isolators being put in so if the UPS was to fail coulddisconnect and plug into the supply's and still have the system running. Whatim concerned is the 400v between different phases with these supplys which areideally going to be within arms length. Common sence is it would be alllabelled up stating where everything is fed from and warning signs of differentvoltages and the room will only be under strict control of supervised persons,im just wondering if this would all be ok? Have been doing a search andcame across something like should never put 400v in same cabinets but can'tthink of a solution to please this IT chap, must think uselectricians are magicians and everything is plain and easy!!
