Discuss Plastic light fitting in the UK Electrical Forum area at ElectriciansForums.net
Hi to anyone who could help please,
In the below light fitting I have connected a single (red) wire to one side and a single neutral(black) wire on opposite side. There’s a spare black wire and three earth wires which I’ve connected to wago connectors. There are three spare reds which are isolated with tape that are not touched. When I turn the mains on the light comes on but cannot switch off. When I took the previous light fitting off the live, neutral and earth were connected correctly to respective terminals and could switch off fine. Why am I unable to turn off the light does anyone have an idea please
Chris
The “spare black wire” is a little concerning.
You really need to employ an electrician to trace the cables and find out which ones are live, switched live and neutral.
We can possibly “best guess” but we are unable to give step by step instructions due to forum rules.
If you post your location, there may be a forum member local that can help out
Did you take a photograph of the old fitting, before disconnecting anything?
Hi,
Thanks for your reply yes I’ve attached below, there’s two black neutrals and a single red. With the new fitting I’ve used the same red and one of the blacks used a wago connector on the other. To be honest I’ve tried both blacks on their own and together in the new fitting and I have the same problem?
Thankd
Chris
Probably the red in the fitting at the moment is a permanent live
The wiring connections seems to have been messed up by yourself
It would probably be a very simple job for a spark, so hopefully it may be not be too costly
Hi,
Thankd
Chris
What you have done here is create a very dangerous situation by disconnecting the outgoing neutral wire, this will lead to it becoming live and a number of light fittings in the property not working but having both connections live.
It would be best to get an electrician to fix this for you and I would advise switching off the lighting circuit until it is fixed.
Reply to Plastic light fitting in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
