Discuss pool pump connections terminals help in the DIY Electrical Advice area at ElectriciansForums.net
M
Michael C
I accidently removed power supply cables from my pool pump
Advise please on what terminals to connect to. Red, Black , Earth-
Any help greatly appreciated
I think that whoever wired that in the first place was either colour blind or was running short on cable as he seems to have used whatever has come to hand!
I think you will need to get an electrician in to trace the circuit out and re-wire that little control box properly.
And without getting 'holier than though'. That is a special location in the electrical regulations, also getting it wrong could have catastrophic results.
Best take the advice above , for the sake of the users.
That SWA also needs terminating properly. The earth terminal doesn't look like it's screwed to the DIN rail properly. Just a couple of issues I have seen at a glance.
I recommend getting an electrician in to go over this and correct issues found. I imagine if it has been installed like that, it has never had any proper testing done on it and it may well be unsafe.
Reply to pool pump connections terminals help in the DIY Electrical Advice area at ElectriciansForums.net
I have a 20 amp gfci pool pump breaker that trips only when the pump is off during the night. Pool pump runs fine all day. I turn pump off...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
Hi, I'm trying to understand legislation in the UK for using an air pump in conjunction with a swimming pool with regards creating and supplying...
I have a 4-wire well pump (red, yellow, black, and green) which just quit. Cycling normally, then shut off and never came back on. I've gathered...
