Discuss private low voltage supply in the Australia area at ElectriciansForums.net
ok. whilst I have peoples attention il quiz sum more. when doing pir on older property how come they can still be passed if they conform to older regs? And how far does this go.. lighting without cpc etc
as if they had to be brought up to current regs then every bloody amendment would mean half the country getting there installation changed every 2-3 years!
Ok, but I'm talking about as a tester would you be happy to pass an installation if it conformed to a reg that was ancient, even though you know nowadays it would get shot to pieces under the 17th? And what about if this place was commercial and served the public surely then it would have to be approached as if it needed to be up to 17th??
only pass id deviations are code 4's. 1's' and 2's are fails.
If the installation conformed fully with the previous Reg's that prevailed at the time of installation, then it will, or should be just as safe as it was at that time. No later regulations can be retrospectively imposed on that installation....
Reply to private low voltage supply in the Australia area at ElectriciansForums.net
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi, We are working on a Solar installation in the UK and have been asked to replace the string cable terminations, 6mm² yellow insulated ring...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I'd like to wire a six pin DPDT rocker toggle switch to turn a low voltage LED fixture on and off. The rocker toggle switch I have is an...
