Discuss Question on PV module and inverter for solar exam in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
A
asop
I have a solar exam to take, and i cam across coup,e questions that i am not 100% sure what the correct answer:
1. When replacing a Solar PV module, what parameters should you match it with? I think it should match Voc and Isc, is that correct?
2. What the Inverter need to match with the utility power line? Voltage and frequency, is that correct?
please comment if you confident of the answers.
Reply to Question on PV module and inverter for solar exam in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello, My current 2.5kW Solar pv array is in a less than favourable position, but there is plenty of space to expand the array. I have an...
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
V.early days, just had installed solar. No battery, also supply of some parts difficult at the moment so no App or Online monitoring. I have a...
Good Afternoon All, So I have a new situation to me that I cannot seem to get a definitive answer for. I trained as an electrician and did...
Good Morning All! Always appreciate reading the great ideas and conversations in the forums, and now actually have a chance to ask a question...
