G
gupster
Hi first post here, did have a search around but couldn't find previous posts that answered exactly what im after.
Had a look at a friends electrical wiring this eve and trying to advise them, as they are now unsure of the "future proofing" they have done would be compliant. (Im not a sparky but have a fair electrical knowledge so eaiser for me to ask the questions).
They have a TN-CS System with a main fuseboard in the kitchen and due to the location of the board they have run some extra cables to add submains at a later date so they dont have to get back to the main board if they want extra circuits.
Main fuse board:- Split load dual RCD
Cable to possible sub main 1:- 6mm T+E & 10mm earth to the loft so they can add another board for a future loft conversion.
5 light fittings LED
5 Double Sockets
2 x 13A Spurs
Cable to possible sum main 2: 10mm T+E & 10mm earth to boiler room.
2 x Light fittings LED
2 x 13a spur
2 x Double Sockets
1 x Water Immersion heater
Then they would like another sub-main from this to the external workshop which would be run in SWA and would have:-
3 x Double sockets
2 x Light Fittings
After they explained all this I quickly realised it was well over my head! My questions would be RCD protecting the sub mains and allowing for discrimination. And if a sub main from a sub main in this maner would be acceptable?
Thanks in advance for any help
5 Double Sockets
2 x 13A Spurs
2 x 13a spur
2 x Double Sockets
3 x Double sockets
2 x Light Fittings
