Discuss rcd testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
relating to testing RCD for effectivness etc....and recording dataAon certificate:eek:n site guide says "remove supplied load" before testing (using megga1720 tester) as the main switch is the rcd....do i need to discon every cct on the mcbs prior to testing? whipping out the bus bar maybe?
not so bad with only a few ccts but when theres 2 c/us and 20+ ccts?:coolgleamA:
Reply to rcd testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
So to start off with i’ll tell you i’m a young electrician, 23, I am qualified but obviously will always be learning. Was carrying out an eicr...
