Discuss RCD trips when power lost in the UK Electrical Forum area at ElectriciansForums.net
Customer complaining that RCD trips when there is loss of power - lives out in the sticks and had some power outages during the winter storms.
CU is an old Wylex fuseboard with a 30mA RCD at the front end. TT earthing. RCD trips OK on test.
Can replicate the fault by simply turning off the main switch on the CU. Doesn't seem to be related to any one circuit being energised at the time of switching off.
Can anyone think of why the RCD should trip when power is lost or when the power is turned off?
Am planning to replace RCD with another and see if that exhibits same problem.
You say that it is an old Wylex board. I'm guessing you may have the old Voltage operated RCD affectionately known as VOELCB.
These work on voltage fluctuations rather than earth faults and are often activated during electrical storms.
Would this be the beastie ?
my VOLCB tester.
ae235
as in a witch trial. if it breaks, it's innocent. if it survives, it's guilty.
Reply to RCD trips when power lost in the UK Electrical Forum area at ElectriciansForums.net
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
Hello. we have had a few powercuts over past few months and am in middle of one at the moment where power has gone off a few times while DNO are...
4K
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
