Discuss Re using old switches in the UK Electrical Forum area at ElectriciansForums.net
R
Robert Turnbull
I'm about to re-wire a old house and it has a lot of old brass toggle switches. I have spec'd new antique brass switches from wandsworth which adds about 1k to the price but they are quality products and i have used them before so i can recommend them. They can make custom plates as well which is good as some of the switches are non standard config.
The clients asked why we cannot reuse the old stuff.
1. Most likely has no earthing terminal....
2. I wouldn't like to guarantee really old switch gear.
Is there a reg/rule that would cover this? I wouldn't usually install a second hand item as such, but not saying they might not be good for another 100 years.
They have asked if in some way they could be earthed can they be re-used.
I haven't opened one up as had no intension of reusing them and this discussion has come to light after i visited site which isn't local.
theres a company called `olivers` that sell repro dolly switches...
problem with the old ones is their open contacts inside and the brass fronts are often missing the card anty flash guard that they were fitted with...also the contacts often dont `snap` open or closed rather they just drift in and out..giving rise to arcing....
The problem you face really Rob is reg 511.2.
These switches may have adhered to some sort of standards when produce all those years ago, but whether they are the same standard as the BS EN 60669-1 is doubtful and if you reuse them as you can as per reg 511.2, you as the designer. installer must be able to prove that these old switches are of standard, which would be very difficult to do if anythnig went wrong
well the dolly switches he`s refering to Malcolm were made up until 1967.....the `jellymould` ones tend to date from the 30s...
my mother has some that date from the edwardian age someware stashed away...they look like grenades..lol...but all tend to suffer the same problem as regards compliance...shame really...
popular manufacturers of these included LANDOR, CRABTREE AND VOLEX. there were others as well....
Rob..
save those switches wont you...together with the round or square wooden patresses they will be mounted on wont you....
their quite collectable now....especially the 2 way ones and the intermediates...oh yes, they were configured like that as well...
Completely agree Glen there is a great chance apart from a lack of a CPC lug, which can easily be fitted, these switches would be spot and give another 50+ years of service as they are more than likely to have been built in a time where standards and processes are much more stringent
Unfortunately in today's world where at a drop of an hat someone is always looking for someone else to blame, if anything went wrong, the OP would have to prove in a court of law that these switches met current standards, and I personally would feel he would have a hard time to do so
Cheers i was fairly sure there would be a reg that would cover this, they obviously aren't up to current standards.
This is what i had told them but i thought i better have a check.
thanks guys
indeed Malc...
I have a collection of these myself...in fact i have a load of white plastic ones that were never used...still in the plain cardboard packaging they came in..lol...yes its perfectly reasonable that you could solder on a lug for R2...
and a quick R1 R2 would confirm it as well...
there would of course be an issue as well Malc with the way the fronts just unscrew....not really secure barriers & enclosures to me....
I guess the best he could do would be to take one apart to measure the separation distance and take a photo and also throw a load of 1kV through them on an IR based test, together with working out how to attach a cpc to the body.
and another thing that may be of interest as well is the new wooden patreses that come with repro versions of these dolly switches are designed to cover a standard lighting knockout box....
so there you go....
Reply to Re using old switches in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Rewiring an old farm cottage… every wall brick and previous wiring not done well at all. I can’t locate any of the prescribed zones diagrams on...
