Discuss Recessed Lights - how to unscrew/unmount this model ? to change light bulb in the UK Electrical Forum area at ElectriciansForums.net
Hi all ! I have recessed lights, like in the photo attached, but I struggle to understand how these ceiling recessed lights unscrew/unmount in order to be able to replace the light bulbs ?
I prefer asking first before breaking something, and can't find existing advise for this type of recessed lights. Am I supposed to use a specific tool for this ? Or is it resisting because the borders of the plastic ring have been painted on/plastered on ?
It is a house built in 2017/2018, and I have a good 40+ recessed lights of this type, of which 5 need their light bulbs changing...
Thanks very much !
You might want to run a sharp Stanley blade round between the ceiling and the bezel first, as they do look like they may have been painted over/around. They should then either twist or pull off without too much effort (hopefully).
I'd be surprised if they were CFL lights put in as late as 2017, but then new builds often surprise me! Maybe the builder got a job lot cheap....
Reply to Recessed Lights - how to unscrew/unmount this model ? to change light bulb in the UK Electrical Forum area at ElectriciansForums.net
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi all, Having some trouble working out how to change this lightbulb. Videos of similar units suggest you should be able to unscrew the white rim...
