M
McChicken101
Hi all ! I have recessed lights, like in the photo attached, but I struggle to understand how these ceiling recessed lights unscrew/unmount in order to be able to replace the light bulbs ?
I prefer asking first before breaking something, and can't find existing advise for this type of recessed lights. Am I supposed to use a specific tool for this ? Or is it resisting because the borders of the plastic ring have been painted on/plastered on ?
It is a house built in 2017/2018, and I have a good 40+ recessed lights of this type, of which 5 need their light bulbs changing...
Thanks very much !
They look like they might be CFL downlights.
Rotate the bezel counterclockwise.
If they are GU10 CFL the bulbs will be slightly longer than LED's but from memory you can buy GU10 led's that are longer specifically for them.
Agree with ferg, rotate the bezel without using any tools. Sometimes the bulb and socket will come out but it depends on the fixture.
You might want to run a sharp Stanley blade round between the ceiling and the bezel first, as they do look like they may have been painted over/around. They should then either twist or pull off without too much effort (hopefully).
I'd be surprised if they were CFL lights put in as late as 2017, but then new builds often surprise me! Maybe the builder got a job lot cheap....
Recessed Lights - how to unscrew/unmount this model ? to change light bulb
McChicken101,
Dartlec,
