Discuss Refuse an install in the UK Electrical Forum area at ElectriciansForums.net
R
Richard3009
If you arrived at a house requesting an extra socket, and the wiring was in the old rubber style with screwits etc, would you recommend a rewire and leave well alone, or henley in a new circuit.
I still come across old rubber insulted wiring that's fine so I'd personally take it on a case by case basis. How did the circuit test results look?
We'll let me just look in my crystal ball and have a look at the house in question ;)
But seriously I would make an initial judgement based on the apparent condition of the installation.
If the installation appeared to be as installed and in good condition (highly unlikely but you never know) then I'd recommend a full EICR to them.
If I was confident that I could justify advising them that a full rewire is necessary without an EICR then I would discuss this with them and recommend accordingly.
I would say chargeable tests would be required on the circuit in question before any decisions could be made. If the client didn't like it, I would walk away, as I have done in the past
Like everything that has appeared before me in rubber,i have vigorously tested it,before condemning it out of hand....many a good tune played on an old fiddle etc :earmuffs:
I tested a house a couple of months back, it was riddled with faults. I recommended a rewire but the owner and landlord wanted a cheap fix of a new CU.
I walked away. You can only do it on a case by case basis considering the test results.
I personally wouldn't touch rubber, its way over due for rewiring.
Same here I wouldn't either , the problem is you could add an extra socket or something , customer would agree with you that all should and will be sorted, once you're out of the door they take no notice and then it can all backfire when something happens , plus you don't know whats going on with the hidden parts anyway ,,,
As said already it highly unlikely you find rubber in good nick , most I have come across has been poor if not bad ,,
I have come across rubber that looks absolutely fine, but was rewiring anyway. I have also found it where the cable passes IR test fine but the insulation crumbles to the touch. I have never left a piece of rubber in service yet.
Absolutely, hands on the stuff in will fall apart in most case's , in fact I would go as far and say in all case's.!! (it has done it's bit of long overdue service)
Could I have an example please.
The cable itself will be fine it depends how much the rubber has deteriorated, I would bend a bit to see if it crumbles before getting mft out though.
When rubber dries out it becomes brittle so if it is going to be left untouched with no vibration I would leave it in service but still recomend rewire
My thoughts reflected in a lot of posts out with rubber and in with PVC I would only offer a rewire, having said that you could argue that fitting them a new RCD board would be doing them a favour, but I would walk away.
I think NOT. Have you tried to change the board in a house full of aged rubber cable? The insulation falls off the cable as soon as you touch it in most cases.
I have experienced both some houses where the rubber is in surprisingly good order and others where it is powder to touch, a rewire is money well spent, lets face it if you come to sell the house somebody will flag it rightly or wrongly.
Reply to Refuse an install in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Client has purchased a night flat in Edinburgh. Its perfect for using as a ST rental during the festival as the agents claim £6k a week is the...
5K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
