Nov 15, 2023
UK
Had a new unvented Boiler fitted as the old one had reached the end of it's life. Electrician mentioned that it might be worth replacing my fuse box and giving it a separate RCD. My fuse box appears to have 10 black switches and the 3 red main ones, was last checked by an electrician in 2020. Cost is about £600-700. Just not sure about the pro's and con's and obviously after buying a new boiler if I should do it sooner rather than later as the cost is a fair amount for me.
Anything that would help me make the decision would be gratefully received.
Stick a picture of the consumer unit on here for better advice.
I’m not a fan of changing them unless there’s a good reason and clear benefits.
Reactions: SpudPower12
Unless you have an rcd in a separate enclosure then it would be worthwhile upgrading that board.
Is this a UK domestic installation? Triple pole main switch and the rail mounted contactor give it a bit of a 'continental flavour'.
Reactions: DPG and timhoward
Yeah, it's in East Anglia, UK
I have to agree, I'd also be suggesting there are benefits to upgrading that one.
RCD technology is a good thing and it's getting rarer to find no hint of it at all.
That looks like a metal enclosure? Hager RCBOs are about £15 a pop, so about £150 for parts. Can anyone see why it shouldn't be upgraded rather than replaced?
Very much appreciate your advice, thank you. The flat was built about 20 years and I imagine it's probably the original board. I'll get it upgraded.
No metal closing lid would be the obvious one I’d of thought🤷‍♂️
Sorry, my bad, It does have this swing door as part of it
As a cheaper option I'd agree you would at least get type A RCD protection with minimal disruption.
For about £150 more in parts you could have surge protection and RCBO's that switch the Neutrals too (Hager's don't) giving better isolation of future faults.
Reactions: nicebutdim and DPG
UK
Replacement Unvented Boiler installed - Do I need a new Electrical Box?
UK
SpudPower12,
timhoward,
