Discuss Replacing a hard wired oven with a plug in in the UK Electrical Forum area at ElectriciansForums.net
Wez
Hi. I'm hoping for some advice regarding an oven I want to purchase.
I currently have a gas hob that is also connected to the electricity for ignition etc.
My oven is hard wired. However, I wondered whether it is possible to blank the hard-wired socket and buy a plug in oven instead. Is this a relatively simple thing to do?
There is probably no reason why the existing connection point cannot be replaced with a socket although if the existing circuit does not have additional rcd protection then strictly speaking this would not be correct however, you could argue the socket would not be utilised for general use.
Reply to Replacing a hard wired oven with a plug in in the UK Electrical Forum area at ElectriciansForums.net
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi, My current oven is hardwired to a fused connection plate with a 13Amp fuse inside and power switch. That is then connected to the MCB labelled...
Hi all, I replaced my old Electrolux oven which operated with a 13 amp plug. The new Kenwood oven I ordered says a 16 amp (Requires hardwiring to...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
