- Reaction score
- 9
Hello, thanks for any advice-
I have serviced a fire alarm in a 3 story victorian building / converted to self contained flats (prior to 1991) for some time.
We have the job of renewing the fire alarm system. The old one is staying in place until the new one is online (no rush).
In most of the flats I've ever worked, the MCPs on landings have been on the zone for the communal stairs, or the building has been zoned Ground floor / first floor/ second floor with everything on one floor on one zone. However after completing an FIA course over a year ago, I believe I was told that (preferably?) in such a case as this (2 flats per floor, 3 storey, 2 flats open on to every landing) each flat should be on its own zone- and the communal staircase on its own zone, and the MCPs should be located WITHIN the zone they should apply to, e.g. instead of having 1 call point on each landing and one at the final exit on the ground floor, there would be one inside the entrance door of each flat- (and one at the ground floor exit door)- x7 MCPs in total.
I have never came across a system where the MCPs were located inside the flats (e.g. in this case it means 7x MCPs in total instead of 3, and persuading tenants to let us drop trunking down inside).. as far as I can remember. What is the acceptable way of siting the MCPs / zoning the system in this case? (This is a mixed system, the communal FA consisting only of heat detectors to entrance lobbys & kitchens, smoke detectors to stairs, + MCPs)
The system is being replaced as part of works to tidy the place up- previously two generations of TV aerial cables, door entry system, fire alarm, emergency lighting, virgin media, BT etc have all been clipped hap-hazardly all over the communal hallways and landings and it is easier to replace than to tidy it up (old FA zones cabled in T&E with 15 layers of paint etc)
Any thoughts on this?
