You just proved it by those words.We've all seen sockets burned out. Not that long ago I had to replace a 63A socket which had completely burned out and had a plug stuck in it. This doesn't prove anything.
Discuss Ring Final Circuit - spurs only in the UK Electrical Forum area at ElectriciansForums.net
Hard wiring a permanently connected appliance, rather than permantly plugged into a portable appliance outlet, make matters safer.You inferred that a 750W fridge was the cause of thermal damage to a socket, whereas the response pointed out that other factors were much more likely to have caused the damage - factors which aren't removed by hardwiring an appliance.
What might these be?OP's thinking fails to take other regulatory limitations into account.
Proved what? That a badly made connection overheats? We all knew that already.
I'm sure we've all seen plenty of burned out hardwired connections too.
Perhaps you could expand upon this as I fail to understand how a 750W fridge is 'made safer' by hardwirng through an outlet plate, than connected via a BS1363 plug/socket arrangement.
Reply to Ring Final Circuit - spurs only in the UK Electrical Forum area at ElectriciansForums.net
