Discuss Ring Tests on periodic in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
and that is why you should test ring continuity.1-0 to you
naughty corner for whoever did the previous work.
Only if there's "critical" equipment on them. In which case convince them to get them converted to radials!
still have to de-energise radials to test R1+R2.
anybody'else struggling to read the microscopic print on the forum today?
echo that one. wouln't dare turn off our house when the soaps are on. that would lead to a critical situation.
no beer fridge. real ale at 50degrees. corner of garage best place. ice cold beer is for australians who wouldn't know a good beer if it bit them un the arse.
IEE guidance suggests that it may be unnecessary to verify continuity of ring final circuit conductors if there is no evidence that a ring final circuit has been altered.
Here here! Cold beer is for crap lager drinkers, they make it so cold so you can't taste anything (as it actually tastes awful).
If you actually like to taste a good beer, drink it cool, a few degrees below room temp.
Back to the original, yes do ring contiunuity. I would say taking Zs in leiu of R1R2 ON PERIODIC TESTING ONLY is acceptable (though not ideal) on radial circuits, not on rings. The only way I would be happy with Zs only on a ring is if I could get a consistent and expected reading on every single outlet, which by proxy would mean unplugging the equipment and would make doing it this way pointless.
If you omit the ring tests therefore i assume the R1R2 tests to as it would be silly to do one without the other , how would you know if there are any faults you could have 20 sockets on one radial protected by a 32 amp MCB or worst still a 30 amp 3036 nice ,you would also not be able to identify loads of spurs off the ring , the whole point of a PIR is to identify these Faults before they cause a problem ,scenario kitchen /open circuit on the first socket on one leg of the ring relying on the 30 amp 3036 fuse , washing machine on tumble dryer on , dish washer on , lets have a brew ............ seen it happen !!
as for critical area's 100 volts should do it ... i was joking lol
problem i found is identifying the correct neutral and earths in a cu for the corresponding phase conductors when singles comming out of a trunking to a rats nest in the cu knowing what belongs to what without depowering for a week, you need to establish the continuity of the ring to ensure breaker is correct size
The only reason they drink it freezing cold is so they can distinguish from urine
Ring continuity tests are vital in my little book. As for "IEE guidance suggests that it may be unnecessary to verify continuity of ring final circuit conductors if there is no evidence that a ring final circuit has been altered."
How are you going to know that?
I always think of the slogan on the old beer mats/teeshirts from the Wychwood Hobgoblin ale ... something along the lines of "What's the matter lager boy, frightened you might taste something?".
Reply to Ring Tests on periodic in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Hi all, Carrying out a periodic inspection at a domestic installation. Semi- detached house on a row of houses. I cannot for the life of me...
Refurbishment of dwelling has taken place and the clients insurance company requires a periodic inspection and test to be carried out, A new...
swing over xmas period 22nd dec - 5th Jan. Currently on $60 flat, any ideas on what figure to request
I would like to reuse a 10mm cable to provide a ring circuit in an area. The cable is currently used for an electric shower, still connected at...
