Discuss rotary switch wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J.C.E
Hi guys
Got a swa run to do tomorrow- just the supply for a AC unit
its a single phase 3 core 4mm supply going to a rotary isolator (this is what I am installing)
then another company will be connecting a AC unit from the isolator at a later date
I haven't actually had to install a rotary isolator before!
Its 20a 4pole switch
my question is where do I terminate my neutral?
I guessing my live can go into supply side 1 (or 2 or 3- as only single phase)
but the 4th 'pole' has a switch symbol sticker on it inside the isolator
does my neutral go into the remaining 1,2, or 3 or this forth 'switched' pole?
I know its meant to isolate the line and neutral (double pole)
but I am bit confused as to where my neutral should go...
look forward to your replies
Usually the 4th pole is marked with a big N, if not there is usually a little piece of paper that shows the correct method but like above just pick one of the 3 poles for L and used the 4th pole with the switching symbol as your N.
Cpc and n markings are above the the 2 'crappy' little terminals on the plastic casing of the switch (so wouldnt be isolated when switched off)
saw someone mentioned it on a post i searched on here yesturday...guess it just balances the load across the 3 poles
Your mixing your self up, it may be required to loop a single phase supply through a 3pole contactor if the overload is a 3ph one as it may be sensitive to phase failure thus you run the single phase through all the poles to ensure the overload works correctly for your single phase motor. Some do it by habit to give redundancy on the switching in case of switch failure then you have another contact point to hopefully operate correctly.
Reply to rotary switch wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, I have moved into a property with a 63a single pole rotary isolator controling a inline water heater. Is this safe? Surely it should...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
Hi all, I'm installing a temporary supply to a modular kitchen and need to bring over a new 3PN supply for a new temp consumer unit located...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
Recently started a retrofit where the 3 phase dB has been fitted with bushes through the galv trunking. The single phase supplies outgoing have...
