Discuss Sanyo Hit-N system instaleed, results in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
A
Aquinas_Quark
Hello all, hope this is of some interest. I could find very few results of actual installed systems on the forums, so this may be of some help.
Just had (Thursday 13th Oct) a 15 x (could not fit 16, not enough space) Sanyo HIT-N240SE10 panels + Fronius IG-TL 3.6 inverter.
Location, sunny(?) Poole, Dorset, very nearly South facing, 40 degrees pitch. 12 panels on main roof, 3 on a gable end (same orientation). Slight morning shading from neighbour's tree, slight evening from gable onto main roof.
First impressions - the inverter is very quiet, slight buzz above 1.5kW output, fan cuts in at about 1.8kW; perhaps equal to someone talking quietly.
The inverter goes down to 100W or less output before quitting!
The output fluctuates wildly as clouds go over - often 300W to 2kW within a minute - makes planning use of the generated power a challenge!
640V DC off the panels even at a pathetic 220W AC output from inverter.
Peak output observed so far 3.3 kW (Saturday).
Cloudy Friday, 7 kWh output; sunny periods Saturday, 13 kWh ; cloudy Sunday, 7kWh.
An impotant tip: I made a scale cardboard plan of my roof and cut card rectangles for panels. By putting them in different arrangements I managed to get FOUR more panels on than my installer's software was saying (!!). Software output is only as good as the input one puts in.....
Any questions feel free to ask.
Hi
I am due to have my 15 Sanyo HIT N235s installed this week not a million miles from you (Eastleigh, Hampshire) on Southerly facing roof (some potential limited shading issues from trees) coupled with a Fronius IG TL 3.0. Will be interesting to compare our results.
Richard
Hi Alan
My installer seemed to think the N235s were a better match to my inverter than the 240s with the next size up inverter (I have read that the inverter's peak output should be less than your array's peak for most efficient usage). I don't think it's going to be a big difference though (our systems are virtually identical in terms of array size, yours being 0.075kWP bigger than mine).
I make 15 x 235 = 3.525 kW peak; I understand the inverter runs better slightly overrated, but a 3.0 inverter on a 3.525 system? I would do some research on that (we all hope for slightly MORE kW when it's blazing sunshine - I believe Sanyo panels may give +10% over rated value ; but of course when hot they produce less...)
Cheers
Alan
PS
Fronius site says
DC max 3130 W, voltage range 350-700V DC, max AC 3kW for the IG TL 3.0....
PPS my system £12,400; can I ask what your quote is?
Cheers
Alan
I did question the size originally, but was assured that Fronius's own software says it is the best match for the N235s. Your quote is a shade under £500 less than mine - did you get a 20yr warrany with the inverter? Very good quote if so :)
Yes 20 yr warranty; I had about 10-12 quotes, the one I went with seemed the most informed, and also was cheapest in £/kWp.
Good luck and let me know your output when up & running!
Cheers
Alan
cheapest quote doesn't mean its the best installation ... just the cheapest!
Speak to the installers about how they will complete the installation, i.e. fixings?
Do they offer a maintenance service and if so what are the costs?
Whats covered in their warranty?
Solar PV isn't a cheap throwaway product, you should hopefully only ever have one installation so it needs to be right on day 1.
just my 2p worth
Scott
Hi Scott, I thought my first post was crystal clear; I have had the system installed. 20 years inverter, 10 years warranty on panels, plus 20 year panel output guarantee as normal, 10 year iwa.biz warranty on workmanship (whatever that means). The installer was the most knowledgeable (in fact it was the owner of the company who came to quote) and so far all seems well. Cheers Alan
New posts
Reply to Sanyo Hit-N system instaleed, results in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
Hello All, I'm seeking some advice about a solar PV system we had installed in November 2014 please. After 18 months, we seem to be consistently...
6K
crossplot
C
J
Hello all, I've had a chap come round to talk about getting some panels on the roof before the tariff changes in Jan. I've signed up and am using...
Many system owners have probably seen changes in the performance of their systems between spring and summer. The days are longer and the sun is...
R
Five days without solar but guess I haven’t missed too much yet, thanks to the grotty weather. I’ve had my solar installation since June 2011...
4K
iconnect
I
