Any ideas for an appropriate wall heater for school swimming pool changing rooms? (well detached from pool area but will still have wet bodies in obviously)
Got to be reasonably well protected from abuse
They have currently got twin tubular heaters with steel cages over the top, but the heat output is not enough
Scratching my head a little bit
Maybe go for ceiling-mounted infrared panels, or if it's a very high ceiling, mount them 3m up on the walls, thus out of reach and casual damage.
Depends a bit on the construction of the changing rooms.
The changing rroms are basically two shiplap sheds, that are being refurbished with a couple of benches in
No height to speak of
These are the heaters in place currently, as you can see by the pictures the place is in need of a good update
I suppose its got to be a wall mounted unit, something oil filled perhaps
Already got a wall mounted supply there...maybe shorten and wall-mount heaters a bit higher?
wall mounted air curtain type heaters on a press for 5 minute timer?
I've fitted air curtain types high up in school changing huts - if you've got enough height. With oil-filled, they take a while to heat up, which is not ideal for very occaisional use, unless you leave them on all day. Whereas an air curtain type is instant heat.
The heaters are on timers plus thermostats, but the adjustable controls had to go under very secure covers, otherwise they get unauthorised adjustment!
Are the heaters required just for when the room is occupied or are they required to also provide a level of heat to prevent damp/mold/frost etc?
