Wetroom Store - Network Wetroom Suppliers
Discuss shower and light pull cord in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
mikey12
hi all wonder isomeone could clarify i have been asked if i could swap a shower and light pull cord in their bathroom (only a little job)as this is in a special location and im not replacing or adding circuit am i right in saying this is not notifiable of course will first check current install and protection ie rcd and bonding and on completion a minor works certificate please correct me if im wrong many thanks:D
Spudnik
  • #2
Hi Mike,
Basically what you have said is fine.
Notification not required, not even a minor works really but i would.
M
mikey12
  • #3
many thanks for the reply just another confirmation if circuit in question is not rcd protected will it have to be made this before continuing i would say yes as this is a requirement but just verifying
A
acat
  • #4
Hi
As I understand it providing you are replacing like for like and making no changes whatsoever it is not notifiable doubt a minor works cert is required as nothing should have changed, but I think its a good idea to test and issue cert so that job is done properly.
Chris
Spudnik
  • #5
As before really, repairs or like for like swaps do not need notifying or circuits upgrading to current regs.
Classed as maintenance.
W
wisesparky
  • #6
Hi guys i agree, but when one of the guys spoke to nic about this, they said any works in bathroom (we was changing a blown bulb- we dont call them that do we lol) needs to be upgraded to RCD???
Other thoughts please????:confused:
Spudnik
  • #7
That is the NIC's take on the regs.
However, it is classed as maintenance.
No further work required..
spark1
  • #8
Changing the lighting pull cord may be acceptable with lack of rcd protecction[ although its debateable]
Changing the Shower unit without rcd protection would not be acceptable and would also be in contavention of the manufacturers warranty/instructions[ read the installation instructions]....additionally the work would be notifiable if the new shower was of a higher rating.
spark1
Reply to shower and light pull cord in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Scolmore Electrical Products
Top Bottom
