Discuss Signal tester in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
E.E.I
hi, what do you guys recommend to buy for a signal tester. I've seen the pocket sized ones but not sure they are any good??
I'm not a full time installer but when doing re-wires I get asked to install the aerials, I've been lucky until recent at getting good signal strengths. Hence I'm looking for a tester
We often install coax and occasionally install TV aerials & distribution if required as part of a job e.g. new build/major renovation.
We use an inexpensive SLX signal finder and it does enough for us to point the aerial in the right direction. When it comes to areas of very poor signal and the different aerial types, boosters, understanding gain etc. I get a bit lost.
I'm very much the same, looking at the SLX it looks bit basic, my brother has used one, even though it showed a good signal strength he had to point the aerial in a different direction for the TVs to receive a picture!
Thats the model I used I didnt like it and ended up using the (argumentive twist and shout mode with the wife telling me all was fine when it was not!)
That model is available at screwfix for pocket money Try it and take it back if you carnt get it to work. the reviews were reasonable maybe it was ME ? or I had a faulty unit.
http://www.NoLinkingToThis/p/slx-digital-signal-finder/58244
Reply to Signal tester in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Hi gents, after some product advice from those who do test-and-tag on a semi-regular basis. We've got a customer with an MCC where all the...
Hi there - good site. Mrs wants a new socket directly below a light switch on the ground floor (says it will look neater vertically inline)...
Reaching out for some help/guidance and sanity check. Apologies in advance for the long post, but wanted to make sure it was clear. Thanks in...
Hi, I've got both a solar pv and an ashp system. The solar system also has 2 batteries and it's configured to fill the batteries first and then...
