Doing a pir in an office which was wired about 8yrs ago. Had a look above the ceiling and noticed the main supply side of the lighting transformers are supplied with single core cable, drawn through flexible conduit. The flexible conduit is not glanded into a box. The single core cables are terminated into a choc box. What code would you give this in the report? Cheers!
