• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Smart switch wiring issues in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Sean
Hi all looking for advice in solving a problem I have?.. I have installed a 3 gang WiFi smart switch. 2 of the switchs are working as they should. Wiring I have.. Black/red/earth x2..red/earth x1. How its working.. Earth's to back plate together.. Single red to L. 2 blacks to N. Other reds to L 1 & L 2..these are working fine... 3..empty...how do I get L 3 to work?.. Is there a loop way?.. Any advice would be great thanks..
Don’t suppose you took a photograph before you took the old switch off?
Are you sure the black cables are neutrals? How were they connected at the old switch?
the 3rd switch will not do anything because there's no cable coming out of L1.
No I'm not sure they are neutrals but 2 switchs work.. I did try moving black wires. One left in N. Other to L1.. This left no power one way. And made no difference the other..
Reply to Smart switch wiring issues in the Electricians Jobs area at ElectriciansForums.net
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
