Discuss Smeg cooker tripping randomly in the UK Electrical Forum area at ElectriciansForums.net
Intermittent faults can be a bit of a pest to find sometimes.
They are by nature not always immediately obvious.
It may be that he was unable to replicate the fault as it may be something inside the cooker heating or cooling that causes the issue.
There is also a possibility that it's a neutral earth fault on a separate circuit.
Sounds good.
Coming from a French background i wonder if any of the experts in here (since i'm not one) think it's a reasonable suggestion that the AC RCD could be the problem? I've had a look at the cooker there doesn't seem to be much electronics on it so maybe this suggestion is bunk but i just noticed the AC RCD and it sprung to mind.
It'a apparently got an induction hob, so it's got around 7kW of electronics I believe ?
Thanks for the advice.
Little update, I have borrowed another range cooker that has induction hob and electric oven but not has powerful has the smeg (don't know if it will make any difference) just to see how it goes, so far 2 days in and no issues at all i will let you know how it goes over next few days.
Reply to Smeg cooker tripping randomly in the UK Electrical Forum area at ElectriciansForums.net
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
I hope this is the correct thread. I have to replace the main oven selector switch in a Smeg A4-5 cooker. I can't find a proper service manual...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
