Discuss Socket and see/ testing shortcuts. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
K
KNIPEX
Hi guys, right before i buy these items could do with your input on them.
first of all the telk 400, which converts an extension lead to a wander lead for checking main bonds are continuous, seems a great piece of kit, not too expensive either,
anyone got one?? are they worth it??
2nd is the sockets and see lamp test kit LTKIT basically instead of unscrewing the ceiling rose you remove the lamp and plug the adaptor in, seems good although pricey, however only has 2 terminals so i fail to see how these can be used for zs where you need all 3.
can you only use this equipment with socket and see testers rather than say a robin/fluke??
thanks for you help in advance.
Hi Knipex
I have the kewtech lightmates their a good piece of kit very handy and yes you will need the cpc but free's up a hand makes life easier as crock the rose cpc and norm the EAW regs only permit zs on sockets all other circuits are calc
Hey mate.
The extension lead adaptor is a good piece of kit and like you say easy on the reddies too.
Those lightmates will work with any test leads I dont know about getting the whole set though maybe just the 2 more common ones.
Cheers.
Reply to Socket and see/ testing shortcuts. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Apologies if this is in the wrong section - appreciate it's more of an educational question. That said I have 2391 - but the classroom environment...
Hi guys, a bit of advise needed if you can help. So i was doing an EICR at a family members property they own and rent out. Its an older property...
My Current Setup (see image BEFORE.jpg): The wiring for my existing detached garage is shown (see image BEFORE.jpg). The house consumer unit...
