Discuss solar power in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You would need a battery system to power the lights at night, batterys charged off the panels during the day. If the house is dark during the day then the solar systems would probably give enough power for the lights during the day but if you are using other appliances why would you need the lights to be fed separately? Any excess not required by the lights produced on bright days would go to run the other appliances.
Reply to solar power in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Can someone recommend an immersion controller that turns the immersion on when the is excess power from solar panels. Thanks
Hello everyone, can someone please introduce to me the low-light performance and double-sided power generation efficiency data of Maysun Solar's...
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
So a family member wants to put an outdoor light or two on the end of a driveway, purely passive and solar powered. These used to be naff and not...
