Discuss spam problem in the Computer and Networking Forum area at ElectriciansForums.net
telectrix
Mentor
getting loads of spam emails from a domain called appspot.com . apparently this is a google cloud based domain and is being hacked with all this crap. can't block them, they come into junk box every day . is there any way to block htis domain or stop the spam.?
you cant really stop a domain sending you email, however your email client can make advanced rules to deal with it. the method depends on your email client. here is an example using gmail.
Google does a good job of sending them to spam, just always periodically check the spam folder for friends emails going into there but if you clock one from your bank or something in your spam folder, it probably isn't your bank and google has clocked the phishing page/email. So leave those there.
Other than that, ignore your spam folder and crack on with your inbox.You can find a setting to remove 'spambox' from your 'All Email' button which is annoying when they show up in that link on normal settings.
I use Gmail for business so it delivers my own domain email to outlook on my phone and laptop, and I have removed the option to show me the spam folder altogether on my devices as it's so reliable usually.
i done that on hotmail but all it does is stop them from inbox. they still come into junk.
you have to make a rule that says delete the emails from the domain rather thank junk them, this depends on what email client you use here is microsofts answer:
1. From your Inbox, click the cog icon
2. Select More Mail Options .
3. Under “Preventing junk email”, click Safe and blocked senders.
4. Click Blocked senders.
5. Put in the domain in the field under Blocked email address or domain:
6. Click Add to
list
You can also try to create an e-mail rule that deletes incoming emails coming from the specific domain to prevent them from coming through your inbox:
3. Click Rules for sorting new messages under “Customizing Outlook”.
4. Click New
5. On the first column to the left you can select Sender's address, second column choose is, then put in the domain on the third column/field
6. Then select Delete these messages—don't even put them in my Deleted folder
7. Click Save
I'm not sure what facilities you have available on Hotmail, but you may be able to setup a message rule that automatically deletes emails from the domain that's sending them all.
As has been said, you can't really stop people sending you stuff.
And just as I'm about to post this... ^^^^ This message arrives :D
Reply to spam problem in the Computer and Networking Forum area at ElectriciansForums.net
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
