M
MDJ
My Job is easy, I get to periodically inspect schools all the time and lets face it, anyone can slag someones work off, however I am not like that and understand we all have problems we need to address, however I recently inspected 2 schools in gloucester which has had some work carried out to them by NICEIC companies, here are a couple or so pictures for your amusement
picture 1, how about this for mechanical protection, this heater is in the school dining hall and was installed 11 months ago by a huge well known company
This is in the childrens cloakroom area
this is work from a company who installed 40 off peak heaters, I have replaced all spurs now, but 25 were burned out, the guy who did the job used the wrong sized screw driver
and this is a recently installed Distribution board, the electrician installed it too close to the left hand wall and couldn't get a screw in to secure the lid lmao
so as you can see being in the NICEIC is very impressive
i mean why have they used copex outside that grille anyway....just dyin to get tugged that is....probably what happened actually...
Yes pretty appalling, I even checked the wall out behind the plastic so called copex and there was no sign of rawplugs, obviously they didn't feel the need to at least fix it to the wall :50:
Mind you that plastic flexi pipe is in 2 halves and you have to click it together, it may have been a better job if they actually used copex.
"big known companies" got couple of boys NICEIC registered to sign the jobs they havent seen, and whole lot of Far Eastern European labourers doing the actual job :(
well i`d have made a note of that...(if containment was intact..but not securely fixed) anyway.....a (3)
but as is...well....
those FCUs are appalling....`wrong driver`..eh?...no excuse is that...just bone idleness is that...
mounting a panel without checking clearance means its now failed visual on barriers & enclosures....
ooh, I went to town on the Job with my periodics and gave them some prices to put all works right, hopefully I will get the Job and the company concerned will have to pay the schools
I've got an empty beer bottle here that could do better.
How completely useless do you have to be...
Liked it for the badness!
ooh, I went to town on the Job with my periodics and gave them some prices to put all works right, hopefully I will get the Job abd the company concerned will have to pay the schools
happy days then......so with a bit of luck these emptyheads will have been installin all over the area you cover.....not bad coming up to christmas eh?..lol....
The heaters are 2.5 kw, the fused spurs burned out, I have already changed them all for MK spurs and used the right driver, several heaters had to have new flex installed as well as no slack was left and it was too dangerous to re-connect, you can't beat a good spark lol
I do 20 periodics every year in schools and am pretty realistic, but sometimes you just have to tell the customer things are just not right and improvements are required
yes well i`m also a believer in being a bit sympathetic/pragmatic whatever with folk`s property....and theres the stuff you can get away with.....but this...
Very true Glenn, it is the easiest job in the world to slag off someones work, usually I avoid doing so, it is not right really, the thing which upset me though on this occassion was the flexible conduits to the heaters, not in the cages and no fixings, to make things worse primary school kids tugging at them, dear oh dear oh dear, I couldn't let that go.
Don't understand how sparks like that can walk away thinking they have done a good job....... No excuses.... Do it properly or not at all!
yeah agree, still suprised at the flexi conduits every time I look the pictures, I just can't believe they let it float about like that in a school dining hall, pretty crap work really, theres just nothing good to say about it I'm afraid.
