M
MissOrange
Hi there,
Ive recently been noing some work on my injector pump, when I pulled the IP out a few wires became muddled and now it doesn't crank. This is a CF Bedford with a LD28 from a Laurel (C32). Its had its original petrol engine and the current diesel, its also run off LPG in the past. The diesel starter circuit has had a manual glow switch installed. Currently the system has a glow plug controller, a glow plug timer, a glow push button, and two relays (this is my current labelling of these parts, photos to follow.
Due to frustration with the sea of wires that seem to not go anywhere (from older electical circuits and fuel systems) and are getting in the way of me trying to figure out the problem, I have ripped a few more out. So likely I have a system where I now need to add some connections.
Here is a diagram of the system I currently have. I need to figure out what I need to add to this system to get it to work again! I dont have a factory wiring diagram, I doubt whether any of the wiring is at all as it would have been originally.
http://i.Upload the image directly to the thread.com/MFCSTLA.jpg
On the fuel cut solenoid there are two wires, I only drew one by mistake, not sure where the other one goes to. There is also a oil sender unit (two wires) that maybe should be in this system too (I missed this off the diagram). And in the diagram #4 is I think a glow plug timer not a starter relay.
Here are some real life pictures..
The glow plug timer? The orange on left goes nowhere
http://i.Upload the image directly to the thread.com/qbnIRX1.jpg
Two relays? (the white wire on left relay goes to the IP fuel cut solenoid)
http://i.Upload the image directly to the thread.com/ZOs9sCE.jpg
The glow plug controller with the manual push button wires wired into it
http://i.Upload the image directly to the thread.com/WVuMk71.jpg
From other diagrams I think this system should have a fusible link in it, unless I have misidentified things, I don't think this system currently has one...
So can any autospark geniuses out there help me out?
Thankyou for any help
