Aico 3000
This official sponsor may provide discounts to registered members
Discuss Strange fault with Drayton programmer in the Central Heating Systems area at ElectriciansForums.net
johntheo
Have you checked the valve in the HW position or/and switched off the power to see if the valve then motors (spring return) to the HW position, it would seem that the valve is remaining in the CH position for whatever reason, what about cylinder stat?.
uHeat Banner - Forum Discount Available
johntheo
OK, but when you say "hot water not heating" you should then be able to establish with a multimeter if incorrect signal is still going to the valve or if the boiler is not getting a signal to fire up or whatever. If just switching the power off-on without removing/replacing the programmer then that would indicate not a pin problem.
  • Mid Position Valve.pdf
  • Y plan mid position valve Operation.docx
Britmanuk
The only fix currently is when the unit is removed and replaced via the bracket.
If it continues to fail CH or HW and it changes from town to time, I'll gent a sparky in again, failing no problems with electrical, I will buy a new brand of timer.
johntheo
Maybe worth having a read.
Reply to Strange fault with Drayton programmer in the Central Heating Systems area at ElectriciansForums.net
