Discuss Stumped! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
R
RS-232
Please bear with me, I’m just an ordinary customer and not an electrician, but I’m slowly acquiring a basic idea of the technology, thanks to the helpful posts from the many experts on this forum.
Please could someone spare a little of their valuable time to explain something that I’m struggling to get my head around - how a PV system connected to the mains can actually work in certain instances?
If I understand some older discussions correctly, an inverter always tries to give a greater output voltage than the mains, so that current flows out of the inverter into the house circuits and if there’s any to spare, into the mains (exporting).
If the panels aren’t producing any electricity (at night) then all the power required in the house flows from the mains and none from the inverter.
What I don’t understand is the situation where the inverter is producing electricity, but not enough to supply all the power needed in the house. I can see that some will be supplied from the inverter and some from the mains, because the lights are flashing on both the generation meter and the domestic meter at the same time. But how can this be, because the inverter and mains are tied together at a connector block and if the inverter is giving an output voltage greater than the mains, current shouldn’t be imported from the mains at all, as it would be flowing ‘uphill’?
There must be an explanation for this, since as far as I can see, it shouldn’t work but obviously does!
Lets say you are producing 3kw from your pv system and you switch you 4kw kettle on, therfore you are 1 kw short, so you import this from the grid, and the cost of your cup of coffee would be 75% less as you have only imported 1kw.
I hope this helps
try thinking about it like a situation where a farmer had a pumped irrigation system with 2 pumps operating in parallel with each other pumping continuously into the same set of pipework feeding the fields from both ends.
The irrigation system has lots of timed control valves to open, close and reduce the flow to various bits of the irrigation system depending on the soil moisture levels.
At different points in the day, the water flowing from the same point in the system could come from either pump, or a mix of both depending on which other valves were opened and closed on the system between it and the 2 pumps, but the water would flow continuously with no noticeable change over between the 2 water sources (unless you stuck some red dye in to one source or something). The overall pressure in the system would vary depending on the number of valves open, which would also mean that the flow rate at those valves would vary, but the pressure on a properly designed system would never be so low or high as to make the pump cut out or stop the irrigation from working.
That's basically how it's working except one pump is replaced by the mains water, and the other pump is set up to push the water out at a slightly higher pressure than mains pressure, but can still only supply a relatively limited amount of flow, so if enough of the valves are open the water from the pump will only reach so far into the system before the pressure drops and the mains water takes over. (water regs obviously don't apply in this situation).
Gavin I am more confused than ever now lol
I class it as black magic and voodoo,
however the way I try to explain it is that electricity is lazy and will want to travel the least amount of distance, therefore if you are generating electricity and require it the electricity from your PV has the shortest distance to travel, if more is required the electricity from the grid will be asked to give a hand.
If you are generating electricity and do not need it the electricity will then look for the next shortest root which will probably be your neighbour, it will go out through your meter and then into your neighbours house and he will be charged by the utility company for the electricity you send to grid.
I try to call it push / pull technology where electricity will travel through the rought with least resistance.
Thanks for your responses, folks.
Earthstore: Yes, I can grasp this, which is why I try to work out if its cheaper to run the immersion heater during the day and supplement the solar power with mains, or run it on Economy 7 at night. It's not always easy to do this, when the sun keeps going behind the clouds!
Gavin: Struggling with electricity is one thing, but plumbing is a definite no-no. Your explanation is going to need some deep thought.
Glen: Yes, this makes sense, but it's the 'pressure' thing I'm struggling with - how can mains electricity, which is at a lower voltage than the inverter, push against it and force current into the same household circuits? I always thought, from my vaguely-recollected school physics lessons, that current flows from a higher voltage to a lower one.
To try and help, the slightly higher PV electricity has been used by your kettle so no longer exists in your wires therefore it allows the electricity in from the grid.
Most houshold items will have a capacitor in this enables in a way a cleansing of the electricity so if you get iregular voltages it smooths it out, before this point under load the device knows it needs x voltage x current for the desired result so simply asks for it from all local electrical sources The PV source has least resistance so will make its path first and stick to it and the grid electricity will take whatever path is left (electrons jumping electrons).
So your PV is 248v and your incoming main is at 246v it will go through the capacitor and come out somewhere between the two with the current to match (this is not the best way of describing it but its the best you will get out of me on a bank holiday monday)
Although i dont really do solar panels etc im slightly bemused not by your query RS 232 but by the replies which if anything they even confuse me, what an inverter does that is grid tied is monitor the voltage and waveform of your mains supply and tries to match it as close as possible, the 'free' electric generated from your panel is then fed into the mains supply, it will choose the path of least resistance which will be back into the grid not generally through your household loads. The meters you have had fitted will measure import and export quantities and your bill will be worked out on the net value, their is no magic gateway that tell the free generated electric to commit itself to your house any flow of current is monitored and calculated by the meters so if you import 20kw and export 16kw then you will be billed for the net value of 4kw unless you have some agreed tarriff in place.
I agree with the inverter bit, the Net metering side however is totally wrong
Reply to Stumped! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi I currently on a job where the garage is having an office built above it with solar panels installed on the roof. I have ran a 16mm 3 core...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
