- Nov 6, 2008
- 254
- 47
- 103
- 57
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
- Business Name
- I H Electrical
Hi Guys
woul it be ok to supply garden lights from a outside socket spurred off the house ring( rcd protected) i planned to change the socket for an ip rated FCU( 5 amp switched) then SWA to an IP box then flex off to lights total load is 4.5amps the lights are only for occaisonal use.
cheers guys
cheers guys
